Unity with M340 Topological Variable Error
Apr 2016
Arizona
44
I am trying to create a DFB that moves 16bits to Word, Word to INT, INT to Array of EBOOL. Basically a discrete output map. For the last function (Array to EBOOL) I created an Output Pin Called DO_Word to be visible on the DFB. I created a tag DO_2 (Array 0...15 of EBOOL) and tied it to the DO_Word Pin.
DO_2 = Array 0...15 OF EBOOL, Address %Q0.2.0.0.
The intent is to have 16 bits read directly into the DO Address. The card is in Rack 0, Slot 2.
I have done this in the other direction DI Address to bits, basically the opposite of above and it works fine. With this DO DFB though I get a message when I build: The topological variable is incorrect.
Any help would be appreciated.
Trent
Trent
Can you post a screenshot of the DFB, i am struggling to fully understand what you are doing without seeing it.
To map outputs from application to physical we normally just use WORD_TO_BIT
Attached you will see the tag created and the DI tag that does the same thing... only opposite.
Also attached is the DFB as I want to use it and the code inside the DFB.
Thanks again for any help possible.
Trent
What I don't understand is why you want move 8 bits to byte and then to array.
You could easily move them directly to %Q address with eight move blocks
Hello. New to Unity and had a couple quick questions. Can a Modicon M340 output to a small multiline LCD screen and not a full HMI?
967
Hello. I'm trying to set up an M340 with a BMX AMO 0410 and a BMX AMI 0410 in Unity Pro XL 13.1. While trying to set up the IODDT for the card...
4,182
Greetings, I'm new at PLC programming, but good a logic - so I thought. I've inherited a PLC system, which is presently operating in the field...
2,489
If I am disconnected from M340, I cant see the Values. Unlike RSLogix when one gets to choose upload state values upon exit, and these state...
2,266
I am trying to make a function that count the number of True BOOL inn a specific Array and return the count to an INT AlarmArrayActiveAlarms. I...
4,443
