Unitypro ladder question
yolandin
Oct 2012
Chicoutimi, Montréal
Hello everyone,
Is there a function to disable several lines of ladder when it is activated. I have several line to desactivate under certain conditions and I did not want to use a NC contact on all these lines. Any got an idea?
Another option - add all the code to a separate section in a task and have it triggered by a conditional variable. Lots of ways to solve this... I suppose my preferred method is to put the concerned ladder in a DFB, then call the DFB conditionally in whatever language you like.
Thank you very much, exactly what I was looking for.
is it possible to external read the Forced_value list from a PLC using UnityPRO? I need to get this data. It could be via modbus, ops... or even...
2,447
Hi, I'm wanting to write a rung that clears a whole output card (64 bits 4 words). I can do it in structured text for each individual bit but...
1,315
Hi All, I'm new in UnityPro. Can you all guys help me on the UnityPro Programming? I need to create a Sequential Table (Recipe type format)...
1,842
Can someone please help me to overcome the version issue of unitypro software. I was trying to transfer the program in to PLC and it throws this...
3,676
Hi Everyone, Is there an RTO (Retentive Timer) function in UnityPro, or do I need to create the block on my own? Any tips would be appreciated...
1,651
