Its all detailed in the help files:
Converting Legacy AlarmSetQuery() Functions
With the release of CitectSCADA 7.30, the AlarmSetQuery() and Query() Cicode functions were replaced with a set of alarm filter functions. If your project uses AlarmSetQuery(), you will need to review and manually replace each instance with the alarm filter edit functions (see Implementing Queries that Use Custom Alarm Filters).
Below are examples of v7.20 Cicode and what the v7.30 Cicode may look like with the new alarm filter edit functions.
Conversion examples from v7.20 to v7.30:
v7.20 code:
INT resultAlarmSetQuery=0;
// e.g. fieldName = Category, fieldValue = 10
// or fieldName = Tag, fieldValue = DigitalAlarm1
resultAlarmSetQuery =
AlarmSetQuery(21,"AlarmFilter","^""+fieldName+"^",^""+filterValue+"^"");//Obsolete in v7.30
PUBLIC
INT
FUNCTION AlarmFilter
(INT iRecId,
INT iInst,
STRING fieldName,
STRING filterValue)
INT resultFilter=0;
STRING getValue="";
getValue = AlarmGetFieldRec(iRecId, fieldName, iInst);
IF filterValue = getValue THEN
resultFilter = TRUE;
ELSE
// when "*" entered -> all values are accepted
IF filterValue = "*" THEN
ELSE
resultFilter = FALSE;
END
END;
RETURN resultFilter;
END
v7.30 code:
//AlarmSetQuery(21,"AlarmFilter30","^""+fieldName+"^",^""+filterValue+"^"");Obsolete in 7.30
//replace the above by direct call
resultAlarmSetQuery = AlarmFilter730(fieldName,filterValue);
PUBLIC
INT
FUNCTION AlarmFilter730
(STRING fieldName,
STRING filterValue)
INT hndl=-1, resultFilter=-1;
TRING sFilter="";
sFilter = fieldName + "=" + filterValue;
hndl= AlarmFilterEditOpen(21);
IF hndl <> -1 THEN
resultFilter = AlarmFilterEditSet(hndl,sFilter)
IF resultFilter = 0 THEN
resultFilter = AlarmFilterEditCommit(hndl)
END
AlarmFilterEditClose(hndl)
END
END
Another example of how this function could be returned:
PUBLIC
INT
(STRING fieldName,
STRING filterValue)
INT hndl;
INT resultFilter=-1;
hndl = AlarmFilterEditOpen(21);
IF hndl <> -1 THEN
resultFilter = AlarmFilterEditSet(hndl, fieldName)
resultFilter = AlarmFilterEditAppend(hndl, "=^"")
END
resultFilter = AlarmFilterEditAppend(hndl, filterValue)
END
resultFilter = AlarmFilterEditAppend(hndl, "^"")
END
END
END
END
