WindowsNT upgrade to Windows 2000 for Citect Communication with S5
Guest
Guest
G
Hi Folks,
When i upgrade the Citect V5.21 SPack G from Windows NT to Windows 2000 Professional , i have this message "Cannot find "siemen" driver..pop up during start the Citect. And the Citect will ask for shut Down..
The PLC is S5 135 and using Serial Communication..
Please help me on this
Regards
the message actually pop up " cannot find serial driver"
the inside the kernal windows is mention" cannot initialize comx " " cannot initialize driver "..
regards
The siemens driver needs to be installed on the computer running Citect. It does not get installed by default when Citect is installed. The driver can be downloaded from the Citect website. Regards Alan Case
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
73
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
178
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
283
