Upgrade GEM 80 Processors
Calistodwt
May 2003
George, South Africa
187
The processors on our GEM 80 plc's are apparently obsolete but the I/O analogue and digital cards are still current. So the plan is to upgrade the processors only from GEM 80-163 to GEM 80-510 and keep the existing I/O cards. We will have to have the ladder logic program converted to give the same functionality as our plant operation will not be changed. Does anyone know if there are any incompatibility issue involved here, or are there any conversion programming tools around to help, or will the conversion be straight forward ? The I/O is a mixture of analogue and digital signals with the analogues being involved with a number of internal calculation functions. The plc's are used on our steam turbine operated generators and perform machine protection and controlling functions
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
108
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
184
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
108
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
283
