Upgrade to Windows10 no more View ME Station
showshocka
Mar 2011
USA
510
Hi. I upgraded my system to Windows 10 and my FTV ME Station 8.0 comes up with an error....any recomindations>? Thx
I feel your pain.
there in not a clean upgrade to windows 10, it breaks stuff.
I had to do an uninstall then do a repair on several programs.
that fixed the issue.
you might try that. good luck.
we use VMware for all our programming, autocad, sql work.
that way, we back up the vm's and if the hard drive crashes, copy them to the new drive and your running.
james
Rockwell software is very picky with Windows versions. You can search in AB compatibility software page to see Windows versions compatibility with FTView ME 8.0. I am almost sure that 8.0 is not compatible with windows 10. You can try downgrade your windows (I like to use Win 7 Prox64) or an upgrade to your FTView.
The maintenance laptop in my plant is with windows 10 (guys from IT refuse to downgrade) and i work with a virtual machine with Win 7 to run the softwares from Rockwell.
Only v9.0 is compatible with Win10, I believe.
At this stage I would get everything onto a Win7 VM, Win10 is a pain at the minute.
I originally upgraded from Windows 8 to 10 (64bit) (an IT forced upgrade)
Soooo guess what? I tried running it today after not using since my OP here (8 months) and Voila'! It magically worked!
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
60
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
176
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
283
