Upgrading 5/01 to 5/03...1747-DTAM "incompatible prog" error
TheCaptain2000
May 2004
Georgia
51
I have upgraded my SLC 500 from a 5/01 CPU to a 5/03 CPU with and without changing data tables and I/O. However, my 1747-DTAM external module now will not allow me to change my values. I have not changed any logic or any of my I/O. Input please.
This is from the DTAM Manual Section 9 on errors
Incompat Program Attach to a processor
The user program in the 5/03 processor is not supported by DTAM
Abort. Contact your local Allen-Bradley sales office.
I guess you'd better 'contact etc.'
yeah, i just found that myself, contacted AB and stated that I need a firmware upgrade for my module. It's going to be $100 or so. I can live with that.
I also found this in a Google search on "5/03 DTAM Incompatible" It refers to the relation between a DTAM and a 5/03 which has the M13 Memory Module installed.
Look at data identification label on rear of DTAM Module. The DTAM Module is identified as DTAM or DTAM-E and the firmware is identified as FRN 0.00.
If data identification label is DTAM-E and FRN 3.00 or higher, this DTAM Module will support new M13 Memory Module # 200684.
If data identification label is DTAM and/or FRN 2.99 or lower, this DTAM Module requires DTAM Firmware Upgrade Kit # 200714 to support new M13 Memory Module # 200684.
Here's the reference
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
550
in my Company I have :- Two CPUs 1747 SLC 5/04 Three CPUs 1747 SLC 5/03 Connected by 1747 PIC converter from RS 232 to Rs 485 to Scada Station...
1,407
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
418
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style. currently we have 4 1394 axis that are all driven by 5kw...
886
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,125
