Upgrading from 1305 on SCANport
woodfritz
Oct 2005
East coast area
Hi Everyone,
We do have several cabinets with SLC5/03 CPU's and two SCANport modules, each.
5 ports are being used, communicating with 1305 VFDs.
We need to replace the old 1305 VFDs, one at a time.
My question: Which VFD's should we use, to make it as close to "plug and play", as possible?
Thanks in advance :)))
I don't have any hardware to try this out with. I'd just be guessing.
I'm impressed that the 1305's have lasted this long! Those capacitors MUST be nearing end-of-life!
If you are using 1203-GD1 and its firmware is later than 2.08 then you can use this with a PF70 see technote ID: QA2645 | Access Levels: Everyone
IN19826 may help.
We still have a lot of 1305's at the plant I work in and also one 1333 still working, quite a few 1336's using serial from a RIO to serial module and a PLC2.
Please confirm: do you plan to retain the SLC-5/03 CPU and the 1203-SM1 chassis mounted SCANPort modules ?
I agree with Alan: the PowerFlex 70, 70EC, and original PowerFlex 700 Standard Control are the most modern drives compatible with SCANPort, and also with the 16-bit data tables used by the SLC-500.
The PowerFlex 40's use DSI (basically Modbus RTU) and the PowerFlex 520 and 750 series use DPI (Drive Peripheral Interface, a successor to SCANPort).
If you were upgrading the CPU or could add a DeviceNet scanner, then the answer would likely be different.
Hi everyone - thanks for the answers.
@Ken : yes, my boss would like to keep the SLC-5/03 and the SCANPort modules.
I can see the point in replacing all the legacy parts, but that is not on my task list, unfortunately.
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
416
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
548
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style. currently we have 4 1394 axis that are all driven by 5kw...
885
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,124
Hello everyone, My company has an old line for building DC motors. Many machines are from the early 90's and some requests for safety...
1,155
