Peter Quiring
Trying to upgrade 316 to 319.
S7 did not allow "replace" option so I saved all blocks online, deleted the 316, added 319, configured IP and uploaded all blocks back.
CPU was running except it was not talking on DP (x2) to main PLC.
In network config the DP was on the wrong network so I changed that.
Now the new CPU will not run anymore, says error with CP342-5. Parameter assignment error. type ID not detected ID.
In the old config the CP-342-5 had a backplane connection field with MPI connection #. But this field is now missing. I think this could be the problem. How do I add it back?
Attached images of old and new projects.
