Upload from a PanelView 550 HELP!!!
I'm not sure why you can't change the port usage. In Panelbuilder32, it looks like you only have 1 port with the DH-485 option selected. See the attached screenshot; a comparison between a DH-485 and DH+ PV600 touch only. The DH+ has a 232 port and you select the usage for this port.
Depends which PV600 you have - There is the option of DH485 comms with Auxiliary port (for printing or download) - 2711-T6C3.
A-ha!
I needed to click the "part numbers" button to select the PV I was actually looking for. The DH-485 second 232 port does seem to be strictly a printer port. The DH+ second 232 port shows as DF1.
I have got a Panel View 300 (2711-K3A19L1) which is currently being used on a production machine. I have not got access to the panelview program...
7,449
Hi! I have a customer with a SLC5/03 and a PanelView 550. I need to extract the application from the PanelView 550, but this model only has two...
4,222
I am running AssetCentre CPR9 with 3 agents. All agents are loaded the same. I ran my first big scheduled backup and compare this last weekend...
2,437
Hi I have a panelview 550 I want to make some changes to, and I need to find out how to com with it. I have a allein bradley usb to serieal port...
2,977
I going to be working with an Allen Bradley Panelview 550 and need to make sure I have all the right cables and connections to Upload the program...
6,513
