Upload program from Allen Bradley Panelview 550 and 300
Rousey99
Apr 2013
peterborough
I have got a Panel View 300 (2711-K3A19L1) which is currently being used on a production machine. I have not got access to the panelview program that is currently on this panelview. I would like to upload the program, modify it and then download it. Is this possible?
As i am new to panelview programming and can not take the panelview 300 offline i have been messing about with a panelview 550 (2771-K5A16) that we have kicking around. I have been able to eventually see this panelview in RSLinx by using a straight through 9 pin RS232 cable from my laptop (with a legacy extender http://www.dell.com/en-us/work/shop/accessories/apd/430-3115?c=us&l=en&s=bsd&cs=04&sku=430-3115) but i can not use the factorytalk transfer utility to upload or download anything. When i go to download or upload anything it errors out and says "The destination selected is not a valid device".
Can anyone help me in what im doing wrong. Is it even possible to use the transfer utility with these old panelviews?
First things first...You need the PanelBuilder 32 software...FactoryTalk applications do not apply to PanelView Standard HMIs and HMI applications...Do you have it?
Are you sure about this catalog number, might it be "M" instead of "K"?
If it is a 300 Micro the one you have supports DH485 protocol. It also would use a null-modem cable
unlike your PV550's straight thru cable.
FYI The Micro's protocol can be changed by way of firmware, if needed.
Tried to communicate with the CPU and then replaced the Battery because the battery was dead. Does this mean that because the battery is dead and...
2,335
Hello All, I am working of a research university and I was asked to set up an old system that was donated to the university. I had to replace a...
5,541
63
Please help me How to B&R 7CP476.60-1 upload program Backup and download which program should I use. Pvi transfer tool.? And how. Thank you
99
in our old machine we used beijer cimrex 41 need to take program backup. i tried it with information designer software through ethernet. ip...
92
