Uploading from a Siemens TP 070
snakeyes
Aug 2006
Melbourne
Is it possible somehow to upload a program from a TP070 screen to a PC, I have been informed this can't be done only download. I am using TP Designer.
Cheers Snakeyes
You can get a util from Siemens that allows you to upload/download the app but this is a compiled version so you cannot load it into the editor, its purpose is for backup restore purposes only.
Thanks Parky, The local siemens distributor here has no idea I will go to Siemens direct. Would you know the name of this util.
Hi Snakeyes.
Latest version of Prosave does support TP070 as a device but only for OS update.
In English that means you can't upload the config:mad: sorry mate
Hi Snakeyes.
Hi BOYO,
it's true,in prosave when I select TP070 I have only the possibility to update the OS, choose the communication speed.
Please is there any other solution to upload from this panel?
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
174
Hello there, currently im working on a s7-200 to s7-1200 migration. Thing is that s7-200 has a TD-200 which contains all of the alarms and i dont...
667
I need some clarification about uploading the HMI file from a Siemens MP277 to edit it in WinCC. Although the machine manufacturer is no longer in...
1,354
I'm using a 3rd party USB to MPI adapter cable. I can see 157 blocks of various types listed under Accessible Nodes in Simatic Manager. The Upload...
28
8,211
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,860
