uploading problems
newguru
Feb 2007
virginia
I need to upload a program from a SLC 5/05 cpu, using RSLinx, what cable and communications network do I use.Thanks for your help.
First PDF will get you on the serial port ( null modem cable)
Second PDF will get you on the ethernet port ( cat 5 crossover cable if from PC to PLC or cat 5 straight thru if using a hub or switch)
Hello All, I have a tetrapak pocket filling unit that I am trying to upload the project from the PLC. I have tried using USB and Ethernet drivers...
19
4,684
Hi guys, I have vipa controller (214) from which i need to upload program to my PC.I am using step 7 software by Siemens via MPI protocol to...
3,042
This is my first posting: I have Problems with Uploading a Panel View 550 connected to an SLC 5/03 Allen Bradley SLC 5/03 1747-L532 PLC...
13,966
Hi, I'm working with a PanelViewPlus1000 and I'm trying to upload some files via ethernet. So far I've been able to download files without a...
4,635
The what: I have an AB Pico 1760L 18BWB-EX, series A and have downloaded and installed PICOSOFT 6.10 Build 2433. This is running on Win XP Sp2 on...
5,384
