newguru Member N Join Date Feb 2007 Location virginia Posts 9 May 3, 2007 #1 I need to upload a program from a SLC 5/05 cpu, using RSLinx, what cable and communications network do I use.Thanks for your help.
Chado613 Member C Join Date Mar 2005 Location Kingston Posts 79 May 3, 2007 #2 use ehternet if you know the IP address of the SLC if not rs232
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,660 May 3, 2007 #3 First PDF will get you on the serial port ( null modem cable) Second PDF will get you on the ethernet port ( cat 5 crossover cable if from PC to PLC or cat 5 straight thru if using a hub or switch)
