Urgent help required!!
rgmiles
May 2006
Mountain ash
53
Hi all.
Can someone help.
I have Omron an AD081 analogue card and i need to display the voltage (0to 10) on an Omron nt31c.
I have the data in memory OK . all channels are working.
I have the screen accessing this memory.
The screen is displaying errata.
what am i doing wrong?
best regards
Bob
Do you have choices like WORDS or DOUBLEWORDS or ASCII and such for the data format to be displayed?
Does your data-type in memory match what the screen expects?
For example, if the screen is expecting an Integer and the particular memory location contains one of two words used for a real number... you will get bogus numbers displayed.
Or is the screen is expecting a Real and the particular memory locations contain several one-word Integers... you will get bogus numbers displayed.
Pierre enquired...
"Do you have choices like WORDS or DOUBLEWORDS or ASCII and such for the data format to be displayed?"
rgmiles responded...
"Don't think so."
Uh-Oh... That's definitely not a good sign.
Typically the data from the module will be in HEX.
You need to set up the Numeral Table entry in the NT to display the value in the format you want to see on the screen (Binary (Hex) or BCD). NT will allow for single or double word values.
Based on this, you may need to convert the value in your plc code to the correct format.
Hope this will help.
I have the logic of OMRON but I want to do this logic in TIA 15.1 CPU 1200...
1,840
I am new with FactoryTalk and I have to modify the HMI which had some work already be done. Currently I am facing a problem how i open a popup...
2,312
Guys, firstly thanks for reading my post. Hope i get a response. I have a .MWP file and i need to access it on an urgent basis...i dont have any...
2,618
hello, All LED's on Siemens PLC(CPU 315-2 PN/DP)are blinking continiously & program is not getting downloaded in PLC.i try to format MMC card but...
8,857
Dear Experts We are using prosoft 35302-DFNT-MCM4 cards. Our requirement is to get some serial RS 485 data & to use it with Controllogix ...
2,945
