Rube
antjon1 said:XIO I:1/0 NXB XIC I:1/0 BND OTE O:2/0
Hope this helps!
Actually it does help!
You're alright Antjon.
Hope this helps!
LOL!!! I really like this guyantjon1 said:OK, here ya go! Just hook up, oh, lets say a 3 phase 480 50HP motor directly to the PLC. Preferably a SLC500 or maybe even a PLC 5. Wire the 3 phases straight into the output card. Make SURE it says on the card "DC SOURCE". Also, here is the ladder instruction you should put in:
Make sure you attach a pushbutton to the 1st Input card. The 50HP motor will make thie lights work through the property of Inductive Reactance. The lights "react" to the induction of the EMF that occurs within the windings of the motor. In fact, if you are using lights that are a long distance away from the motor, you might want to remove ALL fuses from your setup and replace them with jsut a wire to jump over hte fuse socket. That way, you get more current avaliable, and therefore, more reactance.
Hope this helps!
lol
AJ
I'm gonna show my ignorance here. This looks like AB, but I don't know how to read it. Please translate. If I remember my AB, I:1/0 is the first input in slot zero. O:2/0 is the first output in slot 2.XIO I:1/0 NXB XIC I:1/0 BND OTE O:2/0
I:1/0 O:2/0
| I:1/0 |
antjon1 said:- Your very gullible college kid
I:1/0 O:2/0
| I:1/0 |
Hope this helps!
lol
AJ
geniusintraining said:Hey you can fire Rube also...
Rube said:Might as well fire all of us--no one's getting paid.
geniusintraining said:Nice work, Want a job ? you can take over HR dept and fire TWControls ???? if he still works for S&M, Hey you can fire Rube also...
http://www.plctalk.net/qanda/showthread.php?t=20167
