Urgently Help About Profibus
HansAndersen
Sep 2006
Hamburg
132
I am using CP5511.I am installing a new system that will control Boiler unit in our mill.I have created the program with plcsim.I am struggling to communicate the 315-2DP and IM153-1.Both of modules (cpu and et200m) have SF led and flashing bf led.I am using 6es7 972-0bb50-0xa0 as bus connector for both module.I have the addresses as following:
.........MPI.......PROFIBUS
PG........0...........0
CPU.......2...........3
IM153-1...............1
And I have attached the diagnostics and my test program.I realy need help.Thank you in advance.
There appears to be a program error. Select line #4 in the module information (where it says "stop caused by programming error" and there will me more info (where the error is located, etc). This is likely causing your "SF". That's a place to start.
I eliminated that problem.But there is still no improvement.
Concentrate on the "stop caused by" lines in the diagnostic list and be sure to click on the "Help on Event" button for more info on each separate line. Good luck.
I have a alarm banner A display that shows on the botton of the screen and that must shown along with any of two specific main centered displays...
2,070
Hi I'm on a customer site, trying to go online with a GE Fanuc 90-30 PLC. I am using a laptop with actual serial port and Proficy Machine Edition...
2,246
Hi all We are on a critical path of commission a system we are working on with InTouch Scada system. We have three nodes, one development and two...
5,928
Hey all, I'm still new to PLC and I considered myself a quick learner so I wanna shoot straight; can someone help me to explain "in a very simple"...
3,358
Hello everybody, tomorrow i have last exam in school, thing i need to do is to slove whole traffic light simulation in LogixPro. The task is to...
8,614
