USB A/D-D/A conversion board
DrAc0
May 2006
Idrija
Hello.
This might not be topic on PLC-s. But this is the only forum I have found so far, that talks about the problems that are related to mine. Here is the deal. I writting my diploma on A/D D/A conversions. And The board I need, must meet the following requirements.
Sampling 1 KHz (time of the sampling should be max 1ms).
At least 1 Analog input and 1 Analog output. (The more the better).
Desktop configuration (not a PCI card or other mountable in PC)
Conection over USB!
A/D conversion at least 12 bit.
D/A conversion at least 10 bit.
Conversion board must have drivers for Delphi 5.
One of the boards is this one (but it does not have drivers for Deplhi)
www.quancom.de And the card is USB-AD8DAC2
Or maybe there is a way I could reach these requirements with some modifications or maybe converters like (USB to RS232).
So that is my problem, and if anyone can help me find what Im looking for I would be very grateful.
Thanks to all. :geek:
I have one of these, is it fast enough for you?
Code:
[url="http://www.adlinktech.com/PD/web/PD_detail.php?cKind=FN&pid=15&seq=3&id=3&sid=117"]http://www.adlinktech.com/PD/web/PD_detail.php?cKind=FN&pid=15&seq=3&id=3&sid=117[/url]
delphi is OK and I can let you have some sample code if you need it.
Here is one, although I don't know if it fully fits your requirements:
http://www.jaycar.com.au/productView.asp?ID=KV3600&CATID=&keywords=USB&SPECIAL=&form=KEYWORD&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
Or go to:
and do a search on USB.
Copy and paste of text:
USB Experimenter's Interface Kit
Interface your computer to the real world with this sophisticated USB Kit. There are five digital inputs to monitor the state of external switches or controls and two variable gain analogue inputs that can be connected to sensors and used for measuring temperature, humidity, voltage, current, & other variable parameters. Eight digital and two analogue outputs are available for controlling external equipment. The kit is supplied with all components, silk screened PCB, assembly manual, and software. PCB measures 145 x 87mm.
Specifications:
* 5 Digital inputs
* 2 Analogue inputs with variable gain and integrated counters
* Analogue input range 0 to 5VDC
* 8 Open collector digital outputs
* 2 Analogue outputs PWM or 0 to 5VDC
* On-board test buttons for inputs and LED
* USB powered
* Win98SE or above (Not NT)
$69 Australian.
You will need a soldering iron with this!
Good day, I've been browsing this forum for 2 years now, but this will be my first post. I have device with USB serial output. I would like to...
2,784
Hey there guys, i don't know if this question has been raised previously and is just buried in the mass of postings this forum recives but heres...
41
17,868
G'day all. I'm a PLC student and have got hold of a SLC500 system with a 1746-L532 cpu. I am told that the interface convertor will allow my...
9,779
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
156
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
128
