USB Camera vision inspection/measurement software
dpmanthei
Jun 2015
Wisconsin
My company has two Scienscope CC-HDMI-CD2 cameras (https://www.scienscopeproducts.com/cameras/scienscope-1080p-hdmiusb-camera-cc-hdmi-cd2.html). Does anyone have any suggestions for inspection software that works on generic USB cameras? I'm finding lots of software that works with a specific model or brand of camera, but nothing for general USB cameras.
I would like to connect one camera to a desktop PC and display the video feed while detecting the color of one part. A steel needle is stained red with machinist's dye and we carefully grind the needle on a stone until the red color disappears. Even better, it would be great to detect the edge of the stone and the edge of the needle and ensure the angle between them is 0 degrees.
This is occurring at 62x magnification with the option to increase to 124x if needed. Between this magnification and the 1080p 60fps camera, the software should have a good, close view of the part and I can optimize lighting as needed externally.
Thanks for any suggestions!
Dylan
Solved
With much embarrassment, I must report that Scienscope, the company that makes the cameras I have, sells compatible inspection software and it will work on most USB cameras regardless of brand. o_O
"Video Image Essentials works with most USB, USB 2.0 and FireWire cameras which use DirectX WDM drivers."
-Measures diameter, cracks, & other defects
-On screen reticle for Go/No Go analysis
http://www.videoimageexpress.com/software/video-image-essentials.html
So, for anyone else who stumbles into this thread, the cheaper and closer-to-the-metal option is RoboRealm (http://www.roborealm.com/registration/index.php). The expensive, but more to-the-point software is VIE Essentials (http://www.videoimageexpress.com/content/download-vie-demo.html)
I hope this helps someone else, thanks for being here for me PLCtalk!
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
180
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
134
please using the usb can i assign any ip address that i want ?
157
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
244
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
177
