USB communication
jcp
Feb 2010
Multan
369
Hi experts;
I have an issu about new generation Laptops. New Books have only USB ports while in our system system some GE PLC 90-30 are installed. The communcation is done via serial rs232 port.
I used many USB to Serial converter but can not able to communicate with the PLC.
Is there any help about this issu?
Please guide me where from i found a USB to SERIAL converter which works fine and never break the communication?
I have no ethernet card on the chasis.
Regards
I Would recommend you to use Quatech ExpressCard Serial Adapter.
It more pricey the other but it the closed to the real thing.
It is not work on USB .It connected to the PC bus.
It work much better then keyspan which I have too.
You need ExpressCard slot on your computer too.
I have an existing machine running a 1768-L45 CompactLogix and the client wants to add linear actuators...
3,013
I am trying to communicate with Omron PLC CP1E-N40DR-A over USB-to-RS232 cable, using a Java program. Following is my basic code— This code...
3,471
Hi:huh::huh::huh: there, I am trying to get an ADAM 4561 converter to talk via RS232 DF1 to a Micrologix 1400. I know that some USB/RS232...
2,685
I just bought my first micro830 and can't get it to communicate with my PC. I loaded CCW software. When I bring up RSLinx it shows the USB icon...
2,855
I am attempting to perform serial communication with a Thermo-Scientific oil heater's USB port using RS485 communication. I have found a two wire...
1,295
