Micro830 USB Communication
rustyanddusty
Nov 2014
Georgia
I just bought my first micro830 and can't get it to communicate with my PC. I loaded CCW software. When I bring up RSLinx it shows the USB icon but doesn't recognize the PLC. Any ideas?
could be an issue with rslinx
Repair RSLinx Classic from Start --> Control Panel --> Programs and Features then reboot the computer.
Re-install RSLinx Classic by right-clicking on Setup.exe and selecting Run as Administrator
I don't know what the problem is, but here's something you might try that isn't too difficult or time consuming
make a 1 rung simple program. build it, right click on micro830 in the project tree, and try to download it seems like it should have recognized it in linx, but give this a whirl ...see what happens
I assume you musta downloaded the usb driver or it wouldn't have appeared in linx
Use CCW software to talk to and program the 830
check the firmware of the PLC it might need updating
Just read the Pasted part of your post
I would check the USB comport settings - usually you dont touch the rslinx side of this
I am having issues getting a Red Lion HMI and Micro830 controller to communicate. I am using the cable here to connect the controller to the RS232...
119
Trying to put these equations in structured text program in a Micro 830. when I run the verify I get this error. ;:expected before this new...
440
Having to add some programming to a Micro830. I want to add a free running TON, reset with a done bit. in the drop downs or the instruction...
287
Hello, We have a project on our shop floor that for some reason project management decided to not talk to controls about and pick some...
1,325
I have an application using an A-B Micro830 controller. Does anyone have a PDF tutoring how to program one of these. Not very intuitive especially...
23
6,553
