USB connection to Mitsubishi q series extremely slow
smichal
Nov 2012
Gliwice
Hello,
I'm having problem with online connnection to plc Q02H. I'm using a USB cable and a virtual machine with winXP SP3. Connection is extremely slow, watch table refreshes about 30s, sometimes I'm losing connection suddenly. It is PLC and PC independent, we have two PCs with the same VM and connecting to two diffferent PLCs. The same issue is with GX configurator QP we use it for motion modules. What could be a problem? Recently I connected via ethernet using the same PC, no problems.
Thank you.
M
which USB Cable or is it a converter, What is the actual operating system,
Also which program are you using.
Welcome to the site mate for your first post
re
Iant,
It is ordinary USB cable, no converters. Host is the Win 7 prof, guest Win XP Prof SP3. Software GXWorks 2.
I installed a GXWorks2 on host systems. It communicates perfect. It seems like VM player or virtual machine is a problem.
Thank you
M.
That was to be my next comment and suggestion.
you do not need VMware with GXworks2
You need the software version for GX-Works2:
For Windows 7 (32bits edition): Ver. 1.40S or above
For Windows 7 (64bits edition): Ver. 1.62Q or above
Re
Thank you for replies.
The problem is not Win7. I'd like to have all programming environment located on VM. Except for Mitsubishi and USB connection it works fine. I'm using it for S7, CLX, and others.
Regards
M.
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
230
Hello, I am attempting to connect to a PLC and the peripherals via USB to ethernet adapter plugged into the unmanaged switch and having issues. I...
2,670
Hi guys, I'm trying to connect to a CompactLogix PLC via USB; I've done this countless times before. However, now when I connect the USB cable...
7,394
I'm trying to configure a bunch of VFD HIMs via the USB connection on the 525s. Windows will only show it under "Other Devices" as a USB MASS...
11,701
I don't have the USB adapter for this Allen-Bradley 810 PLC, sitting on my desk. So what I want to know is, does anyone have an idea on the...
1,982
