usb-rs232 adaptor comm to slc500
krseee
Nov 2010
bangalore
iam using serial adaptor to communicate with PLC.
whenever i do onlne changes the communication breakes .
can anybody suggest good ideas to solve this issue?
iam using windows xp-service pack-3 installed laptop.
is there any special settings to avoid the communication breakage
What is the part number to your PLC?
You have two ports on the PLC, the top one is DH485, for this you will need a 1747-PIC or the USB version 1747-UIC, the lower port is a DB9 (RS232) for this you need a 1747-CP3
I am guessing that you are using a cross over cable or 1747-CP3 and a USB adapter correct? if this is the case you have two things that may be causing your issue
1) Your USB to serial adapter is not very good and is loosing your coms, then RSLogix will fault
2) You have another software on your PC that is screwing with your Com port
If its number 1, you should try another adapter such as Keyspan or a complete USB-1747-CP3... if its number 2 you can try changing your com port to a different number to see if that helps
Best of luck!
Until recently, I haven't had to connect to a piece of hardware using a serial connection in quite sometime. Well, that all changed yesterday when...
33
6,364
New plc programming computer has window 10 pro 64 bit and tried USA-19hs adapter but drivers are not up to snuff (no signature no whql certified)...
3,581
Hi everyone. I have been doing some reading and getting mixed results. Here is my question. I have a RS232 module on my PLC. I want to connect...
2,141
Good day, I've been browsing this forum for 2 years now, but this will be my first post. I have device with USB serial output. I would like to...
2,789
I am trying to communicate with Omron PLC CP1E-N40DR-A over USB-to-RS232 cable, using a Java program. Following is my basic code— This code...
3,471
