usb to 232 comunication cable
james power
Jun 2002
hello all thank you for just reading my problem .
Ihave bought a new lap top and need to connect to an modicon 984 compact plc which is useing modsoft .The problem is i only have two USB ports and i need an rs 232 port :( Ihave purchased a usb to rs232 converter and tryed but i cannot communicate with the PLC .My computer tells me that the device is connected correctly .
their is no response i have used the convertor on another device an it does work.My computer is a compaq presario1200 which i find has never given me any problems the convertor is a belkin usb to 232 convertor.
has any body else had this problem.Is their a dedicated cable i can purchse
regards [email protected]
[email protected]
This is an issue that has plagued many BUT there are solutions in most cases. You didnt state what specific PLC you were connecting too, that will help the most in providing answers
The worst case I have seen is trying to use an AB 1747 with the USB adapter...just wont work in most cases, has to do with timing issues and APCI. I solved that issue by obtaining the PCMK card.
Overall the best solution (the most expensive though) is to get PCMCIA cards if available. I have them for AB and Siemens. For GE Fanuc, AD/Koyo I have no problem connecting via USB.
Just a thought...
The default setting for Modicon products is RTU which uses a precise 'framing' time period to control the start of a new message frame. You must use a 'real' RS232 serial port to communicate using RTU. Most Modicon products have a means of changing from RTU (8 bit) to ASCII (7 bit) which doesn't rely on precise timing. Set the DIP switches for the comm port to ASCII configuration, change your PC serial port configuration from RTU to ASCII and give it a try.
Until recently, I haven't had to connect to a piece of hardware using a serial connection in quite sometime. Well, that all changed yesterday when...
33
6,322
New plc programming computer has window 10 pro 64 bit and tried USA-19hs adapter but drivers are not up to snuff (no signature no whql certified)...
3,560
Hi everyone. I have been doing some reading and getting mixed results. Here is my question. I have a RS232 module on my PLC. I want to connect...
2,132
Good day, I've been browsing this forum for 2 years now, but this will be my first post. I have device with USB serial output. I would like to...
2,782
I am trying to communicate with Omron PLC CP1E-N40DR-A over USB-to-RS232 cable, using a Java program. Following is my basic code— This code...
3,451
