USB to Ethernet Converter
Dec 2015
dallas texas
Hello, New here so hello to everyone.
Ill start with the situation im having.
Previously we had a Data Discovery program which we used to collect live data such as supply temps and return temps etc. We stopped doing this for a long time and now we are trying to use it again but this program is old and requires a specified com port in which it can look to communicate to the PLC with (serial). Our new PLC's are mostly always Ethernet now and I need a USB to Ethernet converter and I'm looking for some advice on which one to buy if anyone has any suggestions or can point something out to me I would appreciate it.
We use Allen Bradley if that affects anything
Welcome to the Forum !
Does the Data Discovery program now have an Ethernet protocol driver, or will it still be using a Windows COM port ?
Is the Data Discovery program limited to a specific range of COM ports, like COM 1-4 or COM1-8 ?
Which family of Allen-Bradley controllers are you using; PLC-5, SLC-500, MicroLogix, CompactLogix, ControlLogix ?
USB to Ethernet converters are cheap and common; you can buy one at any office supply store. What I think you're asking for is something more specific that can help you connect your legacy software to a modern controller.
It only has Windows Com ports
Its limited from 1-4
Its a CompactLogix
Basically yes you're right that is what im after, will a common one from bestbuy and staples work or is there something special I should look for?
Also If I connect to this through the Ethernet how would I be able to go online at the same time? Surely this isn't possible
Ethernet and TCP/IP protcols make it very easy to connect multiple devices to the CompactLogix at the same time.
The 1769-L24 family controllers can talk to at least 32 devices over unscheduled TCP/IP connections, so it's no problem being able to go online and communicate with a supervisory or data logging application at the same time. The limit might be higher but I don't have a reference manual handy.
If you're unfamiliar with the basics of how Ethernet networks function, with multi-port switches and IP addresses, turn to a co-worker or the Internet for a tutorial. You won't get too far with this project if you don't know the basics of Ethernet.
What you need is a device that can emulate a Windows COM port and translate a serial communication command into a Rockwell "EtherNet/IP" protocol command over Ethernet.
Do you know if that Data Discovery program works with CompactLogix controllers ? If it's so old that it only supports Windows COM ports 1-4, it's possible that it was intended for PLC-5 or SLC-500 family controllers.
What I would recommend for this application is two devices:
Tripp-Lite USA-19HS USB to RS-232 adapter.
Digi One IAP Serial to Ethernet converter.
The Tripp-Lite (formerly Keyspan) device is the USB/RS232 converter I always recommend. It has reliable hardware, good performance, and very good configurability. I know that I have configured one for COM1-4 in the past.
The Digi One IAP can be configured to take a DF1 protocol command on the serial port and translate it into an "EtherNet/IP" protocol command on the Ethernet port. It's the "IAP" industrial automation protocol feature of this device that makes that possible.
It's not plug-and-play, and will require some research and testing. But I'm confident it will work, based on the information you've supplied.
When i left work last night it came to me that obviously I would have to use a switch to connect to the PLC, thanks I will give it a try tomorrow right now I'm still waiting for some parts to arrive I will be sure to post what I've come across. It may be that it's to old, I've already had success doing this through 500 and using serial. Was a huge pain having to map addresses as the plant was updating from an old Honeywell system to a newer system.
I am trying to learn the ins and outs of configuring a NET ENI series D for a project where I will be connecting it to a Micrologix 1500. I have...
4,488
Hello, So, the laptop that i have to temporarily use has no lan port. Does anyone have a proven working usb to ethernet adapter brand? I have to...
2,083
Hello, I am attempting to connect to a PLC and the peripherals via USB to ethernet adapter plugged into the unmanaged switch and having issues. I...
2,684
Hi All, I have had a look through this website but can't seem to find what I am looking for. I have a virtual machine running Windows 7. My...
3,105
I have a Hitachi WJ-200 VFD and an Idec PLC, both with an USB port for programming. We have a remote access device that only has ethernet ports...
3,420
