Usb?????
yudiwp_ind
Jun 2007
Jakarta
Hi there. I am using Mitsubihi Q series PLC, and I use USB cable for data transfer & monitoring from GX Developer to PLC. Unfortunately, as usual, the USB connection is not as easy as plug in the USB connector to the PC. Windows XP ask for the USB driver that I could not find it everywhere. Any suggestion ?
I connect the PLC to 2 mitsubishi inverters, and 3 mitsubishi servo. I could not run online monitor on the GX Developer after Inverter & servo turn-on. USB connection always lost after the devices turn on. Anyone can help?
Basically I do not trust USB for PLC programming but in this case I could not find the better way .
It depends on your version of GX, there is a driver that comes with GX this is called ECUsbd.sys
it should be located in Melsec\Easysocket\USBDrivers
there should be a info file as well.
I have used the usb many times even on an 8 plc system, patching it through the master on USB via the NetH & never had a problem.
I have never used PLCs before. I need help connecting to this thing, nowhere can I find the drivers for it?
25
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
185
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
162
please using the usb can i assign any ip address that i want ?
164
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
245
