use bit as alarm trigger
shishi
Jun 2017
italy
hello forum
i need to use bits of integer and long data type for trig alarms with opc driver in ifix. i saw that with digital Alarm(DA) i can specify the bit with ";;/bit" after i/o path but i need also something that allow me to use 32 bits,but i do not know what can i use.
Since you can't have a trigger value=0 in the alarm setup, you need to start with 1 but in my logic/FTV my xxxxx[0].0 = trigger value 1. How...
7,594
Hi, In an Alarmview there is the Alarmtext. But our customer wants to show the triggerbits of the alarms in the Alarmview. There are 350 Alarms...
2,184
Since Siemens is big endian, is there a quick and easy way to determine the trigger bit for discrete alarms? I'm looking to implement something...
5,082
I'm having an issue setting up the alarm trigger for a PanelView Plus 1500 connected to a PLC-5 via DeviceNet. Other indicators, etc. seem to be...
6,277
I've got a plant with around 500 different instruction-based alarms. The plant would like for the sirens and beacons to go off when any one of the...
2,505
