Use Hashtag (#) in FactoryTalk Text Box
JJH
Oct 2015
South Carolina
57
I am creating a text box for a screen that has the following layout:
/*N:2 {::[MACHINE]Program:UN_Machine.EventSlot1} NOFILL DP:0*/
#1
#2
#3
/*N:2 {::[MACHINE]Program:UN_Machine.EventSlot2} NOFILL DP:0*/
#1
#2
#3
/*N:2 {::[MACHINE]Program:UN_Machine.EventSlot3} NOFILL DP:0*/
#1
#2
#3
/*N:2 {::[MACHINE]Program:UN_Machine.EventSlot4} NOFILL DP:0*/
#1
#2
#3
Problem is, FactoryTalk thinks the #1, #2, #3 are for parameter files, when I really mean is for Number (#), not Parameter.
Anyone know the right way for me to use a hashtag symbol in a text box as a text object and not an instruction for FactoryTalk to do something else?
Are you using FTView ME or SE? What version?
I am creating a text box...
Are you using a Text object or another object?
... for a screen that has the following layout:
#1
#2
#3
I tested a similar code in a FTVME screen and it works correctly (#1, #2, #3 are printed literally on screen).
Could you post a capture of the object's properties?
FTVME Hashtag
Attached is a screenshot of the property.
I'm just using a basic text object as I often do displays with that and just have the variables in there. Thought I could do the same thing, but I forgot the # symbol is interpreted as a parameter file in FTV, which is not what I want it for.
Ok. My first test was in FTVME 6.10. Now I was able to reproduce the issue on FTVME 8.10.
I think there are some workarounds:
a) Create a string tag in HMI Tags and use it instead of the hashtag. For example: if the tag's name is hashtag (type: string, length: 1, data source type: memory, initial valur: #), you can use it the Text object:
Code:
/*N:5 Variable1 NOFILL DP:0*/
  /*S:1 hashtag*/1
  /*S:1 hashtag*/2
  /*S:1 hashtag*/3
/*N:5 Variable3 NOFILL DP:0*/
b) Add and space between the hashtag and the number
Code:
# 1
# 2
# 3
If I can think of another solution, I'll post it.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
209
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
48
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
107
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
143
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
94
