Use prosave to backup Siemens OP 35
Plc_User
Dec 2005
Belgium
317
Hello,
Is there a possibility to upload an OP35-panel with Prosave. When I go to the selection box in Prosave to select the type of panel to upload, I only see panels like OP37, OP17 etc. but none of the older panels like OP35. Should it work when I select OP37 to upload the image of an OP35 panel?
We have a OP270 Touch 10 and are trying to get a Backup using Prosave. It starts and seems to be getting Image1.img and then on to Image2.img...
4,893
I am facing a problem at time of taking backup from Siemens TP1200 using Prosave. "Could not establish a connection. check your setting, interface...
1,767
Hi, I have TIA v14 and v15 on my laptop. Prosave is v15. Can I backup recipes with Prosave v15 from an HMI where there are recipes stored on...
1,626
Hello I want backup pooram from op7 with prosave. How i go Transfere mode? Whith whick keys? Pls help Best regards Nec
10,665
Hi, I'm working on an Siemens integrated C7 CPU 633/P unit (S7 300 CPU with OP7) and have a question on what actually gets backed up/restored...
2,978
