ProSave recipe backup
odonnea2
Oct 2006
Dublin
17
I'm working on an Siemens integrated C7 CPU 633/P unit (S7 300 CPU with OP7) and have a question on what actually gets backed up/restored using the Prosave application with data type selected as: Complete backup (backup of firmware, configuration and recipe data).
Do the actual data records get backed up/restored or is it just the recipe structure. I have tried to find this from the various help files but have had no real luck. I understand that there is an option "Export_Data_records" which stores data in a .csv format. I just need to have a backup of the actual data records in case of unit failure, so i can restore the system to its current state.
If somebody could advise on the best option or point me to where this information may be held, i'd appreciate it.
Thanks in advance....
I am facing a problem at time of taking backup from Siemens TP1200 using Prosave. "Could not establish a connection. check your setting, interface...
1,751
Hi guys, I'm looking for a scetchy piece of software called DecoderProsave. I saw it being mentioned a couple of times on this and other forums...
38
16,926
Hi, I have TIA v14 and v15 on my laptop. Prosave is v15. Can I backup recipes with Prosave v15 from an HMI where there are recipes stored on...
1,613
Does any kind person out there have a copy of DecoderProsave they could let me have Thanks Andy
1,421
Hi! Does anyone have anymore software for decoding prosave- file? Google says that it is called DecoderProSave.exe, but all dl links are dead...
8,371
