Prosave backup recipes
userxyz
May 2002
any
2,768
I have TIA v14 and v15 on my laptop.
Prosave is v15.
Can I backup recipes with Prosave v15 from an HMI where there are recipes stored on flash and where the TIA version is v14 on the panel ?
Thanks,
Combo
Prosave is v15.
Thanks,
Combo
I THINK Prosave is mostly Portal version independent; it just gets its image files from the portal install. I guess probably HW updates get included at some point, too, for new panel types.
Okay
Okay,
So this means that I can backup the recipes from the panel before I download a migrated v15 version of the panel. Afterwards I restore this to the Flash location with prosave and this should work ?
Thank you,
Kind regards,
Combo
Okay,
Thank you,
Kind regards,
Combo
I haven't used Prosave specifically for backing up recipes. If it can snag just them, then it should work. However, I think the backup is the OS and everything. Then, if you upgrade the panel to V15, when you do the restore it would probably go back to V14. Sorry if I didn't understand your question before.
I'm not aware of too many reasons to go to V15 on the comfort panels. I think there were some new ProDiag features, but nothing jumped out at me and said I WANT THAT. You might be happy just leaving it at V14 (inside your V15 project).
You should also be able to plug in a USB stick/SD card and copy the files over manually.
I am facing a problem at time of taking backup from Siemens TP1200 using Prosave. "Could not establish a connection. check your setting, interface...
1,740
We have a OP270 Touch 10 and are trying to get a Backup using Prosave. It starts and seems to be getting Image1.img and then on to Image2.img...
4,878
Hello I want backup pooram from op7 with prosave. How i go Transfere mode? Whith whick keys? Pls help Best regards Nec
10,653
Hi, I'm working on an Siemens integrated C7 CPU 633/P unit (S7 300 CPU with OP7) and have a question on what actually gets backed up/restored...
2,975
Hello, Is there a possibility to upload an OP35-panel with Prosave. When I go to the selection box in Prosave to select the type of panel to...
4,866
