User defined type size in Logix 5000
AlfredoQuintero
Feb 2015
Yokohama
1,551
Hello. This is a really basic question. I am puzzled by the data type size reported for a user defined type with eight one-bit elements. Why is this user data type 4 bites as opposed to one byte?
Will be grateful for some clarifications.
The minimum size for a User Defined Type (or really any data type) is 32 bits. If you keep adding more BOOL tags you will see that size stay constant until you reach 33 BOOLS, and then it would jump to 8 bytes.
Keep in mind that how you organize them makes a difference too. For example if I had:
BOOL (bit 0 in byte 1)
BOOL (bit 1 in byte 1)
BOOL (bit 2 in byte 1)
DINT (bits 0 - 31 in byte 2
BOOL (bit 0 in byte 3)
BOOL (bit 1 in byte 3)
DINT (bits 0 - 31 in byte 4)
That would require 16 bytes. But if we rearranged it to:
BOOL (bit 3 in byte 1)
BOOL (bit 4 in byte 1)
DINT (bits 0 - 31 in byte 3
That would require 12 bytes,
OG
Guys, I need some advice. I'm trying to use for the first time "UDT" on a CLX processor. I have this pneumatic valve with an E/P transducer that...
18
5,120
hello every one as i am new to this forum i want to know detial of udt in rslogix 5000 does all tags in udt get in my program? if i have to write...
15,987
A while ago I heard that v.15 of CLX will allow Online Edits of user-defined data types. Can anyone confirm or deny that?
4,749
Hi in rslogix 5k Why cant i add 2 Dim array inside a user defined data type(data structure) ? Thanx
3,929
1) I am poor 2) I have written some useful plc code in the past 3) Anyone here ever try and sell a user defined FB?
29
6,676
