User issue on Factory Talk View SE
Jun 2017
Lisbon
24
Hi all, I need your help on Factory Talk issue, also for Factory Talk Transaction Manager, I suppose is the same reason.
Windows 7 - 64
FTV SE 7.00.00
FTTM 10.10
I'm Windows administrator.
Factory Talk Issue:
Error message: (Error:0x800706ba)
Error Failed to load VBA project display cannot be opened at run time.
(This is the error to open the first display).
Message from Rockwell knowledge database:
Error in the OS event viewer mentioned domain controller cannot be accessed to authenticate user.
FTTM Issue:
Can't Start with Services.
Error message:
The Services could not be validated using the specified username....
:confused:
Factory Talk FIX: OCX issue. ActiveX. Needs en-register and register again the FM20DLL. on System32 and Syswow64. This with a valid FM20DLL (from a old version of project that era running in other machine), it may happen needs change the FM20ENU.DLL.
Transaction Manager Fix: Security rules.
I'm modifying a Panel view display and have made my changes, which included requiring people to log in to modify some values. So in order to set...
2,480
I've got a problem that's been annoying me for a bit. My users are set up in ftvme and when I run the runtime on my computer I can log in fine as...
1,817
Hi every body. We have an windows based HMI installed with factory talk SE studio in which we have copied our previous factory talk backup. In...
4,631
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
176
Hi guys! I'm working in Studio 5000 and have a bunch of armorstarts there (+- 40). I need to set up parameters for each of them, mostly just same...
100
