Using 24v+ & GND to power a part-present prox sensor.
Potential short circuits shutting down the 24V power supplies or blowing fuses.
And, ina panel that the problem might not be in.
Why not just get a 2-wire proximity sensor ? They only cost a few dollars.
You can always drive an optical isolation relay in the panel with it if it is not compatible with your inputs.
Hi, I wrote a sequence loop using EQU and MOV instructions and would like to validate that i'm doing this properly. i attached a picture of the...
506
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
55
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
97
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
158
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
310
