Aabeck Member Join Date Feb 2013 Location Detroit Posts 1,860 Nov 21, 2019 #16 alive15 said: Yes, I agree about the grounds. What about the commons / neutrals for 24VDC? Click to expand... Unless the power is shared through the different units/panels then I would not run commons between them if not needed.
alive15 Member A Join Date Oct 2015 Location Montgomery, AL Posts 721 Nov 22, 2019 #17 Aabeck said: Unless the power is shared through the different units/panels then I would not run commons between them if not needed. Click to expand... What are the consequences of doing such things? I don't want to experiment, haha, but maybe someone else has more experience than me ))
Aabeck Member Join Date Feb 2013 Location Detroit Posts 1,860 Nov 22, 2019 #18 Potential short circuits shutting down the 24V power supplies or blowing fuses. And, ina panel that the problem might not be in.
jholm90 Member J Join Date Mar 2012 Location Ontario Posts 155 Nov 22, 2019 #19 Better put the old lever limit switch back in.. nice and durable without that extra common wire nonsense
daba Lifetime Supporting Member D Join Date Jul 2004 Location uk Posts 5,401 Nov 23, 2019 #20 Why not just get a 2-wire proximity sensor ? They only cost a few dollars. You can always drive an optical isolation relay in the panel with it if it is not compatible with your inputs.
