Using a 'Memory Bit' W/ Click PLC
jimbob0
Feb 2019
formeta
Hello,
First off, I would like to apologize for beginner question. I am looking to use a 'memory bit' to keep track of the status of an object.
If there are no inputs after time t, and the object is deployed, issue the retract command.
If there are no inputs after time t, and the object is retracted, issue the deploy command.
The state of 'Deployed Status' Should be FALSE initially.
The state of 'Retracted Status' Should be TRUE initially.
I am using a Click PLC.
I have attached an image with the ladder logic I currently have.
Rung 6 is similar to rung 5, but for Retraction.
Thank you
Hi guys, A vendor recently left us with a machine which has a 5069-L320ER set to load from nonvolatile memory every time it powers up. We don't...
2,070
Dear all, I am a newbie to CoDeSys and I need to establish communication between CoDeSys and non-CoDeSys platform. I came to know that to...
2,764
HI everyone, I am progressing 'reasonably' well in my first project, using a 1769-L24QB1B processor. I have found that I am using about 65% of...
1,946
Good morning everybody. I am having an issue with my computer memory running high and I was hoping someone has had a similar issue or knows a...
3,542
Hey guys, I have an AB Micro850 connected with a PV+ using Modbus and Kepserver Enterprise, and I thought of a potential problem that I can't seem...
4,396
