Prayder Lifetime Supporting Member P Join Date Jun 2014 Location Arkansas Posts 254 Apr 14, 2015 #1 I am using an RTO to log the amount of time a button has been pushed. I was wondering when I add it to the rung how do I set the preset? It wont let me click on it like a ctu will.
PLCnovice61 Member P Join Date Apr 2015 Location home Posts 377 Apr 14, 2015 #2 try off line and download
MarkNightingale Lifetime Supporting Member + Moderator M Join Date Sep 2010 Location In The VAT Shed Posts 744 Apr 14, 2015 #3 It will only let you select the preset after you have defined the new tag as a timer. Cheers Mark
Prayder Lifetime Supporting Member OP P Join Date Jun 2014 Location Arkansas Posts 254 Apr 14, 2015 #4 sorry but not sure what you mean when you say "defined the new tag as a timer". I created an RTO and chose the T4[36].ACC as the timer...
gravedigger02 Member G Join Date Jan 2008 Location New Brunswick Posts 47 Apr 14, 2015 #5 You have to be in edit mode to change the preset.
Prayder Lifetime Supporting Member OP P Join Date Jun 2014 Location Arkansas Posts 254 Apr 14, 2015 #6 I already am..
PLCnovice61 Member P Join Date Apr 2015 Location home Posts 377 Apr 14, 2015 #7 if everyone posted the problem code, at the same time the question was asked the answer would be much quicker!!!
gravedigger02 Member G Join Date Jan 2008 Location New Brunswick Posts 47 Apr 14, 2015 #8 Are you using PLC5 or SLC500
Prayder Lifetime Supporting Member OP P Join Date Jun 2014 Location Arkansas Posts 254 Apr 14, 2015 #9 Studio 5000 with ControlLogix 1756-L71 processor
gravedigger02 Member G Join Date Jan 2008 Location New Brunswick Posts 47 Apr 14, 2015 #10 Can you post the rung in question
PLCnovice61 Member P Join Date Apr 2015 Location home Posts 377 Apr 14, 2015 #11 lets drag it out, please post it so you can help yourself
MarkNightingale Lifetime Supporting Member + Moderator M Join Date Sep 2010 Location In The VAT Shed Posts 744 Apr 14, 2015 #12 This looks like a conversion from an SLC to a control/compact logix. Why are you entering the .acc as your timer? You only need to have T4[36] as the timer. Cheers Mark
Prayder Lifetime Supporting Member OP P Join Date Jun 2014 Location Arkansas Posts 254 Apr 14, 2015 #13 that's what it was.... I dont know why I had chosen t4[36].acc... when i changed it to just t4[36] it worked.. thx guys.
