using batteries in PLC cabinet or UPS outside the cabinet
Charbel
Jan 2012
Beirut
307
Dears,
for indoor located PLC cabinet, my preference is to use UPS for supplying the PLC cabinet, PLC cabinet is located indoor and the UPS will be located indoor.
Batteries in PLC cabinet will have some disadvantages if used inside the PLC cabinet:
1- possibility of releasing toxic
2- needs to have all components served by battery in DC not in AC.
I really appreciate any feedback on this issue.
thank you,
charbel
Dears,
thank you,
charbel
What is the issue you are worreid about ? No issue with VRLA in a cabinet as long as its not sealed.
What load is the PLC equipment and how long does it need to be held up for ?
We use these and don't have any issues:
http://www.pulspower.com/products/p...set]=0&cHash=58ca2705abd6581580152047986f513e
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
60
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
109
