Using DDE with Excel installed on other pc
mulderm
Jun 2003
Netherlands
298
Hello,
I have RSLogix5 with RSLinx Professional and Excel on the same pc
with a Data Highway Plus network using a PLC-5 processor.
I use DDE to do some write/read data from PLC-5 to Excel.
Now I want use DDE with Excel installed on an other pc because I
want the program software (RSLogix5),for security,installed on 1 pc.
How must I this realise?
Must I install RSLinx on the 2 computers?
Must I use a 1770-kf2 interface on the pc where Excel is installed for
convert RS232 to DH+?
Who knows the answer?
Greetings,
mulderm
I use the RSLinx Gateway and connect the computers with TCP/IP address and added Enet cards. Your host computer can drill down in to any RSLinx process and DDE link.
!!Cool Stuff!!
I trying to do something very similar, i could get a very good use to the idea of using the Ethernet, but only have a RSLinx Profesional version, can i still do this? If not, what can i do? I thinking about the use of a DDE server comunicating to a DDE client (thinked in Delphi), but i need to make it available to a Ethernet network. Can u recomend me something?
Hi mulderm,
You can use the OPC source code I sent you to set up a link to RSLinx. You can use OPC from withing your Excel the same way you use it in a stand-alone VB application. Add RSLinx to references and away you go.
Good Luck,
If you've got any questions feel free to email me in the office.
(8{)} ( .)
(Yosi)
Hey all, This is more of a question of "can I do this more efficiently" rather than how do I do this... We collected a week's work of...
3,353
Hi I recently saw an AB/Rockwell guy using a excel spreadsheet of config data which he could read or write to a plc via opc. Anyone got an example...
6,150
Greetings everybody, I'm trying to establish a DDE communication between Monitor Pro 7.2 and Excel 2003. I'm configuring Monitor Pro as a DDE...
4,188
I like to know how to use Rslinx with DDE to excel file. I like to monitor i/o using excel. I want to monitor machine start, stop and faults with...
7,583
I was wondering if anyone could me started on using Excel and DDE to collect data, plot it, and then archive some of the data. I know this is a...
10,060
