Using expressions for a multistate indicator in FTView studio
maynarddon
Nov 2006
usa
Hello. I am new to expressions in FTView. I am replacing a GOT with a panelview and am trying to drive a multi-state indicator with a expression based on the value of an int. The ind. has three states. State 0 is normal int value of 3. State 1 is >3 <15. State 2 is =>16 I can do this in GTDesigner with an expression like this: for state 1: 3<$V<15 for state 2: 16<=$V
I have tried several times but the syntax always fails. Admittedly, I amnext to clueless about this! Thanks for taking time to help. Don
Hi & Welcome to the forum,
Try
if #1=3 then 0 else if (3<#1) AND (#1< 15) then 1 else 2
Where #1 is your tagname (or placeholder if using parameter files)
Cheers
Ian
Ian thanks for your reply. I am going to try that. Since I signed up here I've never had anything to offer. All I do is look for answers to my problems which I find 99% of the time.(y)
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
60
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
109
