Using Indusoft VbSctript to find last insert id in MySql once every five seconds
lunenburger
Jul 2008
Summerside
210
I am using VbScript in Indusoft to insert data into a MySql database.
Immediately after inserting a row, I need to know what that row number is to link another table to that data.
On a similar system, I was using AdvancedHMI and used this VB.Net code:
Code:
            Try
                MysqlConn.Open()
                COMMAND.CommandText = "SELECT Last_insert_id()"
                Dim RunKey = COMMAND.ExecuteScalar()
                TempRunKeyID = RunKey
and that was working perfectly.....
But I can't find a way to do it with VbScript...
I can find the total number of rows, and as long as nothing gets deleted I am using this code:
Code:
'Find Row Number of current Job
Dim sql1
sql1="Select * FROM meererdb.run_summary"
$numCur=$DBCursorOpenSQL("MySqlDB",sql1)
$rownum=$DBCursorRowCount($numCur)
sql1.close
sql1=Nothing
But if the number of rows changes, that won't work...
Any insight would be greatly appreciated
Use the function SELECT LAST_INSERT_ID()
Try that, however, if you insert more than one entry before the function I think it returns the first inserted ID of multiple entries.
Not sure in MySql, as it is a long time since I used it.
Are you looking for an autoincrementing index?
Also, how does LAST_INSERT_ID know which table is being referred to?
I have done this by inserting a unique guard field sands there using a WHERE to find that record and SELECT the index
Indusoft doesn't let you request the ID on insert? Ignition does. I'd bet there is a way. You don't want to use MySQL for this, you want this to be done in the script.
Code:
SELECT MAX(ID) FROM table;
Since it autoincrements, this should work more reliably than the $DBCursorRowCount approach i.e. if intermediate rows are deleted, but may give a different number than LAST_INSERT_ID() if
  • the last row is deleted. or
  • multiple rows are added with a single action.
Although I am curios why LAST_INSERT_ID() does not work; that is a server function, and the client only sends the request.
Does it need a semi-colon? what was the error?
I notice that without an argument, it returns a BIGINT UNSIGNED (64-bit) value; with an argument, it return an unsigned integer; maybe VBS can't handle the former?
SELECT MAX(ID) AS LastID FROM My_Table.
However, this is MSSQL, arghh... just noticed the last post so forget it.
Thank you all for the responses....
I have tried using the following VbScript:
Code:
Dim sql1
sql1="Select MAX(run_key) As LastID FROM meererdb.run_summary"
sql1.close
sql1=Nothing
It seems to work but it is returning the number 1 as the value when it should be 523 (last line in table)
Should I change the command of DBCursorRowCount?
I am new to VbScript and MySql commands so please go easy....
thank you
I just tried
Code:
Dim sql1
sql1="Select LAST_INSERT_ID() FROM meererdb.run_summary"
sql1.close
sql1=Nothing
And it works perfectly....
(It's funny, I am positive I tried that before and I couldn't get it to work????)
thanks to all...
SELECT ID AS LastID FROM My_Table WHERE ID = @@Identity;
or
select *from My_Table order by Name desc limit 1;
select *from My_Table where Id = @MaxId;
or
set @MaxId = (select max(Id) from My_Table)
select *from My_Table ID, My_Row where Id = @MaxId;
Worth trying ?
In MSSQL, I would do something like this:
Code:
SELECT TOP 1 run_key FROM meererdb.run_summary
I haven't used MySQL for some time, but I think the equivalent code would be something like this:
Code:
SELECT run_key FROM meererdb.run_summary ORDER BY run_key DESC LIMIT 1
SELECT AUTO_INCREMENT - 1 as CurrentId FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = 'My_DB' AND TABLE_NAME = 'My_Table'
Auto increment would be the next one so need to minus 1 as above
Code:
Dim sql1
sql1.close
sql1=Nothing
thank you
you were asking for one row (the single max value) and $rownum was correctly set to 1.
What you want was the value of the field in the row, not the number of rows returned.
I just tried
Code:
Dim sql1
sql1.close
sql1=Nothing
thanks to all...
Actually you are still retrieving the number of rows.
if you tried any of the following
Code:
sql1="Select NULL FROM meererdb.run_summary"
sql1="Select 0 FROM meererdb.run_summary"
sql1="Select -1 FROM meererdb.run_summary"
sql1="Select 1e+32 FROM meererdb.run_summary"
sql1="Select 'a modnar string' FROM meererdb.run_summary"
you would still get the same answer from $rownum=$DBCursorRowCount($numCur)
You need to figure out how to the the value of the field (i.e. LAST_INSERT_ID()) SELECTed in a row, not the number of rows (via $DBCursorRowcount(...)).
I have been searching for a way to insert a line into a MySql database once every five seconds. I was using Advanced HMI and the timer tick...
23
6,446
I am working on a project where I need to accumulate the amout of Runtime of a machine. I am presently able to display the length of the "Current...
3,184
Hi, I wrote a sequence loop using EQU and MOV instructions and would like to validate that i'm doing this properly. i attached a picture of the...
582
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
55
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
97
