using l36erms when safety isn't needed
Aug 2021
tecumseh mi
52
Howdy everyone,
I have a project that i am duplicating on an older version of the same cell. With all the additional stuff that has been added the 1769-l30er memory isn't enough, i am about 80kb over the 1mb capacity. The cell i am duplicating has a L33er in it which I have a quote for, but we have a couple extra l36erms from a different project that got upgraded. I don't need the motion or the safety, I just need the capacity. Other than the additional power it pulls, are there any concerns with using this one? Anything I would have to do on the safety side because it does have a safety side?
Empty Safety routines do nothing and have no effect on normal logic. Other that being a little overkill the L36ERMS should work just fine.
I have seen safety faults in processors with empty safety routines. To attempt to prevent that, I always have at least have one rung of logic in the safety routine. Usually that is a rung that unlatches a tag "Always Off".
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
60
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
109
