Using one WinCC flexible Faceplate for 200 pcs of ...
MOeZ
Nov 2009
singapore
101
Dear All,
Is there a best way to do it one faceplate for 200 pcs of objects in WinCC flex RT? In my case, i have done with script for all 200 pcs. is it right way to do it? Plz advices me if u have any others way to do it.
Bgrds,
Sadly, you can't multiplex a structure tag and you can't link a structure tag to a UDT. Using a script to calculate the tag addresses is the best way I've found of using the same screen to control many identical PLC objects.
Nick
Hi
I am interested in the script ideas ... is there an example somewhere for a basic faceplate that i could develop
Thanks for Kind Suggestion. Hello, cjd1965, i will give you screen shot and scripts what i have done so far for 200 pcs (not PCS7) of valves with one face plate.
Hi
That would be good. I dont really need the PLC code, it is the script i am interested in. If it is easier for you to strip it down to only 2 valves that would be fine also.
Post here for everyone to share or I will pm you my email address if you prefer to keep it quiet
Cheers
Hi All, I have to convert my csv file to an excel sheet in Wincc Flexible 2008 for which I have written the following code snippet...
5,034
Hi, I have to convert my csv file to an excel sheet in Wincc Flexible 2008 for which I have written the following code snippet: 'Alarm_Log.csv'...
5,285
Hi all, I am trying to change the property of an object in the current screen. Changing the color of the object works fine but BLINKING property...
5,727
I got this Step 7 Project which is already well define. i have added a HMI device to the project the HMI is a MP277 10 Inch Touch so far i've...
4,121
Dear all buddy, I have 1 project using plc siemens 300 series with ET200 and to communicate with scada is wincc flexi.the project is to show the...
1,349
