Using RSTrendX with Excel
DaveH
Dec 2003
Southampton
I'm successfully reading and writing to an SLC5/03 using Excel.
At the moment I'm trying to get the RSTrendX control to work from with in Excel.
Would appreciate it if someone could direct me in to right direction.
Thanks in advance.
Has anyone had any experience with RSTrendX in excel.
I really need to get this working - don't have access to the AB.com knowledgebase.
This is for home not for the job.
When applying the RSTrendX 'module' to excel - you have the same control as when running the trend application from within RSLogix.
Drag and drop functions or rungs from RSLogix to the RSTrendX running in excel - but the data is not seen. I have tried configuring a pen manually using the same 'code' as used in excel for a hot link to a data value - with no success.
Can anyone help????
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
60
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
