Using SFC20 to copy SDB's
L D[AR2P#0.0]
Nov 2006
UK
6,699
I came across the following coding method which appears to use SFC20 to copy from SDB200 (the SDB used for configured connections) by specifying the source area as DW#16#89000000
Has anyone any experience of using SFC20 for this purpose ?
Code:
      L     P##psource
      LAR1
      L     W#16#1002
      T     W [AR1,P#0.0]
      L     2
      T     W [AR1,P#2.0]
      L     200
      T     W [AR1,P#4.0]
      L     DW#16#89000000
      T     D [AR1,P#6.0]
      CALL  SFC   20
       SRCBLK :=#pSource
       RET_VAL:=MW100
       DSTBLK :=#WData
L P##psource
LAR1
L W#16#1002 // = S7 BYTE
T W [AR1,P#0.0]
L 2 // = Repetition 2 (bytes).
T W [AR1,P#2.0]
L 200 // = DB number 200
T W [AR1,P#4.0]
L DW#16#89000000 // = memory area (*)
T D [AR1,P#6.0]
CALL SFC 20
SRCBLK :=#pSource
RET_VAL:=MW100
DSTBLK :=#WData
*: From Hans Berger and STEP7 online help I know that the memory area is specified as
81 = inputs
82 = outputs
83 = Merkers
84 = DB
85 = IDB
86 = L-Stack
87 = Previous L-Stack
If 89 = SDB, then that is undocumented.
Could be true. I never thought of that you could poke around in the memory like that with SFC20.
I've tried using SFC20 to copy SDB122 in a 317-2DP CPU but SFC20 reports an error saying the DB is not loaded.
I came across the 89 area when wading about in the code recently posted by pethoek concerning SFB14/FB14 - it's in the library that I posted in the thread.
Hi all, i have learned siemens sample code by using sfc 20 for data move. but i don't know how i can adapt this sample code if i would like to...
2,007
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
38
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
92
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
147
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
266
