Using the Move command in RSLogix 500 Pro
RickK
Mar 2007
Iowa
The class I am taking is currently attempting to do a stoplight program using RSLogix 500 Pro, with Allen-Bradley SLC 500 model 1747-L40B.
The task at hand is using the sequencer to run the lights and to have two push buttons to activate the "Walk/Don't Walk" lights. It has been suggested that I use the Move command to make this work.
Any suggestions, or examples? As awlays, the simpler this is, the better it's going to be.
Thank you,
RickK
I use the move command for panelview to give the status of a motor, for example. Very simpl: in your case you could use it to move a value to an integer, as value 0 when stop button pushed, or 1 when when go button pushed. From here you can output the light status to control the crossing, use to flash the 'go' on the push-button, whatever.
Thanks for the help. We got it figured out, if anyone is interested, I'd be glad to post the ladder diagram (in RSLogix format).
RickK
Congrats
RickK
I'd just like to say congrats to a student who looked for help, but didn't roll over and play dead until help came to them. It says something about your work ethic, and I'm sure that it will serve you better for future questions here to know that you are putting in an honest effort on your end.
Russ
Good Morning , I appreciate your help on a previous post.Your advice helped me understand more. My next question involves the same project...
3,561
Good Morning , I'm trying to move a total for a dose into a dose history. I'm able to get my totals to move just fine. I would also like to...
2,407
One of Rockwell engineer had visited our site and activated rockwell software with the help of move 32 bit activator. Now I want to move the...
4,920
Hi, I posted not long ago regarding my setup. I took some recommendations, but I'm stuck good. Sorry if it's lengthy. I have an AB Ultra 200...
28
5,687
Hey! Been a while since I've asked this forum a question but I got great help the last time. We had a guy recently leave and I was given all of...
4,390
