Using Transfer Utility on PC based HMI
Aug 2012
Cleveland, Ohio
Has anyone been able to use the ME Transfer Utility to Upload an application from a pc based FTView 6.0 installation? AB is very vague in the installation manuals and at one point says only that the drivers need to be configured on both ends. The HMI is working fine accessing several controllogix processors over ethernet.
Any advice if no direct experience? I have tried configuring an RSLinx enterprise driver to no avail. Currently in process of updating our Rockwell contract so I am unable to access tech-connect. Any advice would be appreciated.
Why do you need the transfer utility for a PC-based ME Project (ME Station)? Just shutdown the ME project and copy the .mer file. If the PC is on a network, you can copy it remotely, just like any other file.
We are using automated archiving for compliance purposes. This system utilizes Rockwell's transfer utility for FTView HMI's. I have thought about setting up scripts to accomplish what you are suggesting but I would rather keep all my eggs in one basket.
Hello all. Would anyone have sample code that uses a wall clock to move the CTU.ACC to a another variable in the PLC after 24-hours has elapsed? I...
1,938
Good Afternoon , I'm looking to upgrade a Transfer Car that travels about 150' . At the moment it uses DeviceNet. My goal is to eliminate...
1,318
So I have FTVS ME 8.10 and I'm trying to upload PV+ programs over Eth/IP. I have an RSLinx Enterprise driver but I can't seem to make any changes...
2,818
I want to transfer 4 bits from AB PLC(studio 5000, logix designer) to ABB ROBOT(IRB 1600) , the type of data is DINT and send the data when camera...
1,934
is it possible to transfer input and output data from one cpu to another in s7 200 using profibus for program lader logic
1,271
