Would like to upgrade a Transfer Car-Thinking of using Wireless Ethernet or Ethernet
Rob S.
Sep 2008
Maryland
739
Good Afternoon ,
I'm looking to upgrade a Transfer Car that travels about 150' . At the
moment it uses DeviceNet. My goal is to eliminate all Devicenet in the plant .
My question is , I understand that Phoenix Contact , Banner , Etc. have Wireless Ethernet that can be used instead of using communication cables such has Cat 5 thru an energy chain.
What would be your recommendation ? How reliable is Wireless Ethernet to control important automation ?
Thank you so much for your expertise ,
I would stay with Rockwell
I have both used and recommended wireless radio ethernet
in your case probably point IO would work just fine
A plant that we do work in has a trolly system that uses Bluetooth in order to communicate between the main panel and the one on the trolley. Been told it has been rock solid. Might be something to look into.
Does the transfer car travel along a defined path? If so, I'd recommend a solution based on leaky coax. It makes it a ton easier to try to manage channel overlap and things like that on a wifi system.
I've seen Siemens systems that even had the safety signals going over wireless, with no issues.
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
153
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
207
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
190
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
121
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
295
