Using Transmitter or switch
shkoko2000
May 2011
cairo
296
Dear all,
I want to ask about if i have condensate surge vessel and i need to control pump with H and L levels. What is the correct choice using transmitter and take soft trips from it or using switch? Please mention your reference...
The correct choice is what you deem to be the correct choice.
For plain bang-bang on/off control, switches are inexpensive to purchase and install, and can be used together with just a relay to control a valve, or just a starter.
Level transducers are more expensive, and will require external modules to set and monitor the trip points, but after that, can again be used with just a relay of a starter.
Reference: Life.
It depends on your process and the equipment you choose (and budget)
Mechanical style level switches I find are a bit unreliable. Especially since you mention condensate. It is also generally hard to change the positions.
For condensate tanks, we generally use kubler level indicators with analog signal:
http://fluidic-ltd.co.uk/wp-content/uploads/2014/04/bypass_principal.jpg
Here we combine a visual indicator with electronic.
The Honeywell XNX Universal Transmitter describes how to get the number of days remaining until calibration is required using Modbus but I can not...
3,944
Hello, I have a PH transmitter that is supposed to be panelmounted. The cut out is 90*90 mm. This is some standard measure as I understand...
1,783
Hi Guys, I am trying to get a level reading of a tank using a pressure transmitter, I have nearly got the formula that I wont but I'm struggling...
10,697
I'm new to HART enabled process devices and have been unable to find what Foxboro IDP10-T HART differental pressure transmitter variables that I...
2,833
Hello guys, I need your help. I need to configure one temperature transmitter using Hart communicator 275. In data sheet of transmitter I have...
8,589
