V-Memory Locations (DirectSoft)
This particular set of instructions seem to be the setup memory locations for high speed counting. The manual for the particular CPU - or for a add on CTRINT card will give you the meaning of the particular K values going to each of the V memory locations.
Hi again all, wondering if someone can help me. I have a programming running on an M221 PLC and I want to capture some analog data to a series of...
6,273
I have a Direct Logic DL05 (DO-05DR) PLC I'm using with a samkoon touchscreen. I've got communication going between the two using Modbus, but...
25
7,479
I have six single memory locations receiving the number of hours that six pumps have been ran for. I need to know which of these pumps hast the...
1,908
Hello all, Some of you might remember a few weeks ago I was working on adding a bar code reader to a DL06. After some time and help from this...
1,717
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
72
